Roccafellas
- Joined
- May 7, 2017
- Messages
- 357
- Reaction score
- 0
Lmao... Took the converter for a ride?
Hey man do you have a tool that pulls the front crank seal?
Naahhhh. I just improvise
I typically use a self tapper and a small slide hammer, at least of it has the big green metal lip on it. If its the old style, just pull the pump cover and use a cut off wheel to pull the wear ring. Ford actually does not have a tool for the new seals.
Yup. Go real slow and dont cut into the crank... If you get it about half way you can split it with a chisel.
There is no such thing as owning a 6.4 and saving money. LOL LOL. Don't try to skimp on anything or cut corners or you will end right back where you are right now.
this
6.0 swap and be done
