sounds like the turbo is not healthy in the second video.. but the sound quality isnt the greatest on my phone.. whats battery voltage doing at idle?
gonna hook a meter to each glow plug? if you tied in a volt meter flfrom side to side of the gpr, only thing it would show is if there was a significant drop. and btw, if key on power from post to post is more than .25, yes that is 1/4 of a volt, different, then the gpr needs replaced..Dude, that thing cranks over nice with those new batts. I second what Lincoln said, I think you have turbo/uppipe issues. I don't think I can make my truck smoke like that in neutral even when cold and I have somewhat leaky up-pipes.
It would be nice to have some sort of led or current meter on the gpr so you knew for sure it was energizing/working when you were trying to start the truck. I've used some flat/rectangular panel meters at work that would be nice to mount in the cab. Sorry if this sounds like a stupid idea but so many people have issues with the gp system that it just seems like a no brainer to me.
The led is a no brainer but the meter would be even better as you would be able to detect if any of your gp's are out or going out.
I was thinking a shunt style ammeter. There should be a significant drop in current if one or more isn't working. There are also hall effect sensor ammeters that can measure current flow too without actually being wired in. Never used one other than a clamp on style though.
Here is an example of what I was thinking of using. I think full draw of gp's are below 100 amps but cant remember. I'll try to measure it here in a little bit. Should be pretty accurate at 80c and below. Not sure what the underhood temps are, but shunts will start to anneal up around 100c I think.
http://www.amazon.com/gp/aw/d/B00GL...+amp+meter&dpPl=1&dpID=412XKZ4cYtL&ref=plSrch
I just pulled that out of my azz as an example. You could allways use an analog gauge that would probably have a smaller footprint. Do the current based relays use a Hall effect sensor or a coil? That sounds like a a much better option with just a small led.Personally that is to bulky for me, you could get one of those current based relays that clamp on the wire and are adjustable of how much current will activate the contacts. Then just put a light on the dash, as long as you have the set current draw it will come on
http://m.grainger.com/mobile/product/AIROTRONICS-Relay-21EU16
Here is just an example this one is cool because it's self powered there is a bunch of different ones. There are smaller ones. But most take 30vdc. But I'm betting the 24vdc under the hood would run one. you can find them for like 20 bucks if you search around
I see.
