Thanks for the pictures! I'll have to look when I have some daylight available. I mentioned that it smokes at idle, it's barely noticeable at times unless the wind is blowing. I drove it today and it doesn't smoke while driving as far as I can tell, as it has 5% back windows. I've been reading and it could maybe be fuel pressure related? But it has power (until 3rd gear then it bogs, but that's a whole other issue.) so then my next best guess is an hpo problem, then injectors. The icp is almost full of oil so that needs to be replaced, if I unplug it while running the idle doesn't change but it does set of a CEL. So then my next best guess is the ipr. I unplugged it and tried to start and it ran the exact same.. Afaik it shouldn't be able to run without that unless it's stuck. So now that it runs, icp, ipr, fuel filter, hydroboost flush, and line replacement.
