My truck crapped the bed today
DocBar
Akron, Ohio
Cruising along at 70mph and all of the sudden heard a loud ticking noise (not as deep sounding as a thrown rod) and had TONS of white smoke pouring out of the tail pipe.
Pulled into a gas station and had a good amount of oil pour out from around the dust cover ove the flex plate. No water in the oil and the oil level is still good.
I'll try to post a short video I took and a couple of pics of the oil that came out.
I'm really hoping my HPOP is the only thing that's wrong. Wouldn't that cause the white smoke and ticking noise?
7.3psd97444
Indiana
If your hpop puked it's guys out it wouldn't run. Your saying oil is pouring off the back of the motor? Check the valley see where that oils coming from.
DocBar
Akron, Ohio
I sent Vander the video and pics. He's leaning towards injector cups or turbo.
I had the injectors put in by John Wood on Feb 25th and got my chip reburned by Matt at about the same time. I haven't been reall happy with how the trucks been running since then, but I figured it could wait til June so I could get it live tuned again by Matt.
If it's the turbo, I just happen to have a ZQSSB fresh from Pius I can put in.
I have ~100k on the 38R.
weekendwarriorfsw32
Central California
Man that looks and sounds like a cracked piston on a 6.4 but it doesn't explain the oil on the ground unless the crack case pressure blew out a turbo seal or rear main seal or something.
DocBar
Akron, Ohio
232323232%7Ffp83232%3Euqcshlukaxroqdfv47%3A5%3Dot%3E243%3B%3D98%3A%3D%3A43%3DXROQDF%3E2%3B463%3B2%3A%3B%3C245ot1lsi
Oil under the truck. That's all it puked out. Still have full level in the motor.
232323232%7Ffp83232%3Euqcshlukaxroqdfv8544%3Dot%3E243%3B%3D98%3A%3D%3A43%3DXROQDF%3E2%3B463%3B2%3B23245ot1lsi
99% of the oil came from around the dustcover.
Spatel23
Olive Branch, MS
lets see a pic under the dust cover
that amount of smoke with that relatively small amount of oil is strange, unless Im misunderstanding the amount of oil it actually leaked
DocBar
Akron, Ohio
That's all the oil that leaked. The truck is parked at a gas station for the weekend. I might go and pull the dust cover tomorrow.
What's even more strange is that I had white smoke coming from under the hood, too. It didn't smell like oil but maybe the smoke from the tail pipe was masking that. I completely fogged out I-8 for about 2 miles.
ghohouston
Lewisville,Texas
Is the inside of the exhaust wet? Pull your intake off and feel/spin the turbo shaft. Sure spunds like you popped the turbo to me
Magnum PD
VA
I'm worried about the white smoke. Bad hpop line wouldn't make it smoke would it ?
