littleredstroker
I've got a 96 motor sitting in the barn. Was wondering if I could just swap rods from it to my SD and just do new bearing or not
Sent from my HTC PH39100 using Tapatalk 2
Why would the crank need rebalanced? Swap them in. If you want to get fancy, you can "balance" all the piston rod assemblys after you put the pistons and rings on. Weigh each assembly, remove enough metal from the rod to make them all weigh the same as the lightest one.
I would also replace rings while I was in there. If everything looks good on the crankshaft, I would leave it alone.
Oh yeah, have the oil cooler jets welded on.
There's enough of a weight difference...that we would nevvvvver swap forged onto a PMR crank...w/o re-balancing.
Machine shops have called us and said...'wtf' when trying to balance a 'pmr' (originally) crank with forged rods...
so the cranks were balanced...errr...should say weighted differently from the factory with the respective rod.
can you do it? have people done it?? sure...
Cause its got 250 k on it and burns about a quart of oil a week mines got 165
Why not get an entire overhaul kit and build the 96 out on a stand?
And run the piss out of the PMR engine. Doesn't make sense to spend twice the money... I cannot see any substantial good coming out of this. Yeah it might work, for a while...
