Progress thread
Mwilbur516
I would tell them to ship that delete ASAP and see if that's the issue.
Me too. If you swing by and install my new deleted intake manifold, you can have my RCD EGR delete kit, b*tch.
Sent while driving, drinking coffee and threatening to kill people in traffic.
Mwilbur516
On second thought, I don't want your bad mojo rubbing off of Mighty Whitey. I'll install the manifold (eventually) and then you can have my delete kit. ROFL!!
Fox hunt
Am I crazy thinking a weld in the egr cooler cracked and it's pressurizing my cooling system? I've been beating on this thing for two months on the same coolant and it's still passing the combustion leak test. I'll run the test and pass it then bring it back by the exhaust and the least bit of exhaust gas will turn the die green so I know it's not the die.
always possible. I've thought that might have happened to me. only leaks out thr degas at wot, lost some coolant (but in think it may have filled the cooler cause I havent lost any since). interested in what you find, might throw a real delete on mine if it solves your problem.
Sent from my SCH-R530U using Tapatalk
bretferd
Cape Coral, fl
You could get Steve's delta kit, cut the pipe coming out of the oil cooler, and pound in a 3/4" freeze plug into the front cover.
swinky
Eastern, Nc
Well no real progress since the trans, she clean doe
swinky
Eastern, Nc
My firewall insulation is absolutely trashed. Anybody ever remove it with the cab on? Its the insulation that runs behind the turba.
