Chvyrkr
- Joined
- May 18, 2011
- Messages
- 2,204
- Reaction score
- 0
Not sure but if the assemble was balanced maybe just pull the rods and have them checked at the machine shop and then put them back in, no? Or is there some damage that could be done that might not be found that would still have it be questionable?
I'm not sure if the testing is cheaper than balancing.
But, he's gotta pull the crank to remove the rods, so take the crank and the rods, including the replacements, and have them balanced, and bolt it back together. He can take his flexplate and harmonic balancer too, if he wants to dial it in.
The NDI testing we did for cracks/stressed steel on aircraft was fairly quick and fairly straightforward. But I doubt the equipment we used was cheap, so I doubt the places with the equipment provide the service cheap.
what fluid are you talking about? it blew 4 freeze plugs in the rear of the block...
........did you not blow both headgaskets?
