Soot / oil build up? Wtf?!?!
OuchThatHurt
Neah Bay Wa
2012 f250. 94k miles.
Fully De**Ted
I was installing the H&S intercooler upgrade pipe. The one that removes the throttle body.
Found this...
JRLott
TX
Great. One more thing to add to the ever increasing list. :doh:
Jomax
Arizona
yeah , i try to tell people, most are VERY shocked when they see it. gimme a call , i'll make you a deal .
So that is in fact from the CCV? Or does the egr have something to do with it? That looks horrible!
Mike, is there anything out there so the truck isn't a smelly smoky pig at idle when you do a ccv ******?
Jacob @ No Limit
Indiana
Soot from the egr plus oily intake from ccv makes a nasty mess! Jomax, install a ccv ****** and plumb it into the exhaust. No more smell unless you are near your exhaust tip.
Jomax
Arizona
Is the smell obnoxious? My 7.3 was pretty bad, lol
Probably need to just stop worrying and just ****** it for the good of the engine.
Notneb
You'd have to make a coalescing filter/catch can to a CCV re-route to the exhaust to remove the smoke part, and direct the smell out of the tip.
I'll be at the Military Vehicle show tomorrow if you want to see my setup and just how much oil vapor there is.
psduser1
on the road
No ******s yet? C'mon, man.
:biggun::thumbsup:
Hard to drop the warranty!
:stupid: very common when people change the pipe
how common is actually? like 1 in 10 or ? is it only for emissions on trucks or can it happen to the emissions off but intact trucks too?
WHY NOT
Carlyle IL
Mine looked just like that when I changed out my inter cooler pipe. Been deleeted since about 35k miles and had 85k on it when I changed the pipe. I have always had my ccv though
holy balls.. so even without emissions, the ccv can cud it up.. how hard would it be to take off and clean? is there o-rings sealing everything or is it metal on metal? i want to check mine now.. lol
Notneb
It's just the design, some of it gets sucked into the intake. I did my CCV re-route at 3000 miles and there was about a teaspoon of oil in the intercooler piping. As far as taking it off, you have to unbolt the fuel pump to remove the CCV box, it's not hard but it's no 20min job.
JRLott
TX
Sh!t. I was hoping ccv alone wouldn't do that.
