Yeah I'm all hopped up on NyQuil, I meant the filter and lines that connect to it, made it easier for me to get it out. I also did this mod along with replacing all my piping and intake, so I had to remove the plastic intake plenum.
https://www.dieselfiltersonline.com...34rGMEt4E0xqj3FhVwrFuWIxZtYIKzRGMYaAsFK8P8HAQ
http://www.parker.com/Literature/Racor/RacorNews/MAPS/RSL0178_MAP_Doosan_Engine_CCV6000.pdf
https://www.dieselfiltersonline.com...5cxaK1WdcwNi-IK8l0ztbYfafXPZ0i6bpYaAmsN8P8HAQ
http://www.powerstroke.org/forum/ge...hs.html#/forumsite/20554/topics/140812?page=1
Cry once, but once. This is the route I'll have to go, can't stand the smell of the ccv.
Even in the exhaust. You'll be getting a Constant stream of smoke coming out the tail pipe at idle, I really don't want that.
Jomax, I'd like to see some pics of this when you finish.
oh ok.. makes sense now..
so with derete tuning, egr off but still on motor it shouldn't allow eg to go into intake right? so technically if there really is that much build up it was done way early in life or there are other issues..
i just went and looked at mine and the hose comes out of the black ccv box and down to dam near where the compressor wheel starts if im looking at it correctly?
doesn't look like it would be that hard to take the throttle valve off but does it seal with a crush gasket? how do you get the innercooler quick coupler looking thing off the valve?
I was interested in that Parker/raycor set up but for$400 I'll just dump it into the exhaust. I prefer the idea of it not venting to atmosphere, but it's dumped at the transmission cross member, and I can't stand the smell anymore
Dude that sounds good. But my **** smokes like my ex. Literally fire under truck. That racor is prob the way to go with your exhaust dump. You prob already have the cats azzNext week once I get over this cold I'm going to see if I can make the stock CCV box work with my setup, using the H&S adapter to attach the vent hose to it, and thus out my exhaust.
If it works, it might be an option for you too
it's the oil vapor from the crank case vent when routed to atmosphere.Ok. So what is the oil smell you guys are talking about? Where is it coming from? I'm tuning and d3leting tomorrow. Would like to check this CCV stuff out while I'm at it.
Gotcha. I haven't noticed any smell yet. I have a 2012 with 58,000 miles.
