SPE's 7.3 on the Dyno
SPE
Carmichaels, PA (SW, PA)
Employee Scott dynoed his 7.3L PSD today. We made some good numbers and there still some room for improvement.
SPE Built & SPE Tuned
775hp and 1539 ft lbs
FUEL ONLY!!!!
Video on our Facebook page (link in signature).
SPE
Standard Bore & Crank
-Carrillo Rods
-Mahle Pistons Ceramic Coated @SPE
-Hypermax O-Ringed Heads
-910 Valve Springs
-SPE Extreme Duty Push Rods
-Full Force Diesel 400/400 Injectors
-Adrenaline Hpop w/ Gen3 Hpop
-Innovated Diesel Headers modified to attach up-pipes with V band @ SPE
-Cast stainless Up-Pipes built @ SPE
-All stainless polished pipes were fitted and TIG welded @ SPE
-All turbo pedestals and piping were designed, fitted, and welded @ SPE
-Powder Coating @ SPE
-Regulated Return build @ SPE
-SPE Low pressure fuel system
-S464 high pressure w/1.10 housing
-S474 w/ SPE billet Wheel and t6 housing
-Stock intercooler still is used for low pressure
-Front Mount Intercooler 4in Core
-ATS Stage 2 Transmission
-ATS Triple disc billet converter
-Billet input shaft
-2.5inchs of lift on 35x13.5x18s with Dick Cepek DC2s
-TS 6 position tuned by Dan & SPE
-Glow Shift Max Tow Gauges egt, fuel pressure, and tft
-Autometer 60psi boost gauge that gets wrapped on the regular
-SPE Intake plenum
-SPE 8in stack
-SPE Turbo Back exhaust
-AEM Water Meth w/SPE Nozzle
-SPE Traction Bars
-Dual 16in Electric Fan
PABowhunter
Good work. Do you offer any of the SPE built products on your website? Fuel system, traction bars, etc. I didn't see any at a quick glance.
SPE
They are not listed on our site. We are in the middle of transferring servers at this time. We will update our site once everything is switched over. In the meantime, feel free to give us a call. :D
