Swamps 7.3 common rail
Dieselfever
Beaverlick, KY
He might have been sarcastic? Saying, that is 2.6 power. None the less that would make a 7.3 a good runner and more competitive in either class than they are now :ford:
JD3020
Farmersville/Dayton, Oh
Yep, except for the mechanical 7.3's. Which for some reason they seem to get built, pulled some, then are never seen again. :shrug:
Be interesting to see what improvements they make to squeeze some more power out. Aside from head flow, i don't see why a CR7.3 couldn't make the same, or more power than a 6.6
01PSD
Smithfield, NC
Yeah Tommy Hassler's version. Haven't heard of that problem on the dyno with Scotty's though... interesting. Not saying it hasn't happened
02BigD
Coastal NC
There's a huge difference between dyno pulls, and yanking 40k behind the truck for 300 feet.
02BigD
Coastal NC
*sigh*.
Technically I was referring to the amount of time that the rails were being subjected to the high pressures pulling vs making dyno runs with my post. I was simply using the sled as a metaphor.
Then again, maybe Tommie is commanding a boat load more rail pressure than Swamps is. Doubt it but.. Dunno...
Powerstroked162
On Da Juice
Wa. State
*sigh*.
Lol I was gonna say something to him but gave up before I started
Powerstroke Cowboy
Montana
*sigh*.
I see your point. I thought you were referring to the weight.. I was like?????? The thought did run through my mind but I figured since you did not say it you did not mean it like that.
Does anyone know whos are what rails they are using? The 6.4 dont seem to have trouble...
Steve....... :D
Powerstroke Cowboy
Montana
In a FB post he said 50k psi.... kind of threw the :bs: flag in my head but idk.
IF that is the case then i can see why. BUT that seem a little unlikely.. In any case 50K PSI is high. There is systems out there that are being tested that do 60k But never heard of it in a automobile yet.
For??????
