Swamps 7.3 common rail
STROKIN N STYLE
GOM via NC
Did the rod stretch enough to have the piston hit the head and poopoo some parts?
No continued to run all day. You were there I believe, it was in crandall. That's the day I went 11.2 with a messed up trans. All it did when it reved that high was spit the dip stick out of the tube and spit a little oil on top. No big deal
Gearhead
OH, I thought it may have been the one on the dyno that had some bearing damage after seeing some high rpm.
golfer
it's currently getting new piston rings, cam, and our stage2 heads.
the recent single turbo CR engine held over 1000hp from 3250 to 4200rpm...so we have pretty high hopes for the engine going into Scotty's chassis.
