The "I hope it's the last one for a while" build
chromehound
Hastings, NE
So after a little wheeling and dealing I picked up a new ride on 10/1/13
2006 F350 XLT ECLB
6.0L
4x4
Auto
99K when I bought it
The current plan is for a 450-500hp DD that I can still pull trailers when I need to. It'll be slow going as I'm broke as hell most time and I frequently change my plans. LOL
Power plans:
ARP studs
OEM gaskets
Absolute Performance coolant filter
Absolute Performance intake manifold
Absolute Performance trans solenoid
No Limits IC pipes
Swamps 58v FICM
MBRP 4" black exhaust from Innovative
190/100 injectors from RCD
Pro 5r CAI from RCD
Elite HD uppipes
Elite stage 2 trans with deep pan
DPC converter
Bulletproof oil cooler/filter
Full EGR delete
SCT w/ Gearhead tunes
CTS
I haven't decided on a turbo yet so when that gets decided I'll adjust the build around it.
Other stuff:
ICON lift
rims
tires
brake upgrades
radio upgrade
'08+ mirrors
'08+ tailgate w/ backup camera
Harley headlights
Harley grill
Front end protection
PTM rear bumper w/o sensors
PTM side steps or replace
PTM mirror caps, door handles
Leather seats
Tint
Sound barrier
Remote start
Gooseneck
chromehound
Hastings, NE
Day I brought it home
Removed FX4 and door badges
Factory radio had to go so I could use my iPod - can't wait for my double din
Bigger toolbox but still not big enough
chromehound
Hastings, NE
Regulated return is going to go on - probably Stricktly Diesel. I will be doing some kind of pump but not sure what yet. I'm on the fence with Airdog due to the fact I see as many failures as I do successes. Plus I'll be adding a bigger fuel tank and a fresh HPO if this one isn't up to par. Traction bars will be added when needed.
I'm sure there are things I'm forgetting so suggestions are welcome.
Motostroker
I wanted to put a stage 3 MTW on mine. But I tow heavy, so that is out of the question. I'll most likely end up going with 175/75s and a stage 2 MTW, his power max. Your build is very similar to mine
kyle43335
you need a compounded vgt setup.
chromehound
Hastings, NE
I don't intend to tow heavy (of course that depends on your definition of heavy) but I'm not opposed to doing compounds down the road but I really want to avoid having to buy turbo after turbo.
Gotta save some $$ for the black Friday sales and hopefully get my rims once I decide on what I want. Decisions, decisions LOL
chromehound
Hastings, NE
Well *** - I think my EGR valve may be going out. I get a bit of thick white smoke upon acceleration from a stop and the coolant bottle is suddenly empty. Going to investigate more on Turkey Day to see what I can find and send it in for warrenty work if need be until summer when it's getting deleted.
peixinho
I think 190/100 is way too big for your application. You can make 450-500hp on stock injectors. There are a couple of people getting around 600hp on 175/75s. You should be hitting 600-650hp on 190/100s with the right setup
Rest of the build looks pretty good
chromehound
Hastings, NE
Thing is I know me and will want to go bigger and I try to avoid doing things more than once when I can so I figure bigger injectors pulled back with tuning if need be. Like I said my plans change all the time as I read more builds by others and my usage of the truck changes.
chromehound
Hastings, NE
Ordered my CTS, a Fumoto drain valve and 4wd line upgrade the other day.
Added a 1.5amp battery maintainer to keep the batteries happy on Friday.
