If you're hitting 300ish psi cranking, IPR climbing to 85%, you have HPO problem.
Did you "key on" or directly power up IPR during air test? 300 psi is common with HPO leak. Being an 03, common leak spots are limited to Injector orings and pump itself....usually.
You said IPR connector was melted. Is IPR good?
