webb06
Is the coolant and oil being mixed? You think it might be fuel from a line or injector?
If that were the case where would the coolant be going? There are no exterior leaks
Are you using the same heads? Maybe a valve seat leaking?
How much coolant have you lost? Have you had to refill since you started it?
I was going to say. Pray there was just some air in the coolant system and thats why it went down, and its just something as simple as a fuel leak and not another crack. Did you reuse your fuel lines and o rings, or did you get all new stuff?
Mine went down almost the whole bottle after my EGR delete, this was also letting it idle. Still dropped down 2" below the fill line after I refilled.
I think you're alright as far as the coolant is concerned. Hopefully your oil will tell the tale
Did you have the heads checked? MINK had a valve seat machined to much that leaked coolant. Could be something similar
Leaked in to the crankcase? Or where? I didn't have them checked, just machined the very first time
Hopefully it's nothing major. Keep an eye on it. Air in the tank. Or a very small external leak the evaporates before you can see it. At least we can hope for something like that.
My guess is, if there is no sludge on the fill cap, that your fine.
man i sure hope so
