What are y'all doing with the DEF tank?
DWhite
Oklahoma
Awesome, I look forward to checking out your write up on it.
How do you have it tied into the main tank?
DWhite
Oklahoma
I wonder if the little pump inside used to pump the def would work for pumping the diesel from one to the other? If you flushed it out with water then ran some diesel through it. I heard it is a low volume pump but don't know anything else about it.
CATDiezel
This is an awe full amount of work for an extra 5 gallons....
Just take a break and stop and get fuel! Lol
DWhite
Oklahoma
You're probably right and after pulling my tank and washing it out I'll think the same, it is just one of those ideas you feel like you have to try and see if it works.
peont
Pine Prairie, Louisiana
Could you remove the def tank and with the extra space now install a long wheel base fuel tank in place of a short wheelbase tank?
Swsignal5
I drilled a hole in the bottom. Flushed it With a water hose for about 2 hours. Tapped it then put a fitting in the bottom
Swsignal5
Just left everything the way ford put it. I've had it that was 3 years
Swsignal5
There is a fitting going from the bottom of the def tank with a line that goes to my snowperformance pump.
jwlandry
S.W. Louisiana
Probally not but you could use a tank off an older truck that's for a short bed.
DWhite
Oklahoma
dont think they changed tank capacity. both shortbeds so same tank i believe.
He is right, I know the 08-10 short beds have the same tank size.
I'm thinking my buddies 03 short bed also has the same tank size.
