What Do You Tow?
genuineford
Vesper, WI
I think we did pretty good on it. It has all brand new tires, LED tail lights and a fold up dove tail lights. I am going to try and get some paint work done on it yet this summer/fall but we will see.
Ipkyss
Just pull this home today
2004 citation 34ft with bunks in the rear. Very clean and well take care of.
Diesel_Brad
Gilbert PA
It's nice to see someone over secure a load for once, most guys I see would just have one chain on it
Over secure? Each piece of equipment is supposed to have 4 chains and 4 binders(one each corner). Then the bucket and each attachment is supposed to have one chain and binder each as well. So a backhoe would get 6 chains and 6 binders
had to move lots in the rv park the other day... first time with the fifth wheel on her... she is going to need some help in the azz... it sat my dually dead level, even with the 100gal drag tank full in the back... i dont even have the tank in the back yet... its not on perfectly level ground but you can see how much it squats it... its way worse on level ground... due to this truck setting a little higher to begin with im going to have to invert the axles so the trailer sets level... tried to get a side pic on level ground but i didnt have time...
stock ride hight
jacks up..
superstroked
Celina, TX
stock ride hight
jacks up..
looking at the space in the fender well on the front and back, it still looks a little higher than level in the back. As it sits, I would say roll with it but, it will probably sag when you add another 800 lbs to the bed with the aux fuel tank. You never know until you try it though.
7.3 Cowboy
I was going off typical wll that tractor doesn't need 20,000of wll securment but I would have to look at my fmcsa book
like i said its worse when i got it out of the lot and on the flat pavement..
oneton
fla
since when?its 1 chain,1 binder for every 10k.some say that or for every 10ft of load length(load,not trailer)
Diesel_Brad
Gilbert PA
stock ride hight
Think I would be looking at extending the pin on the trailer. WAY to close to the bedside for me. One off kilter move and you have smashed bedsides
definitely will be raising it... thats way to close... but i only drove it 150 yrds around to the other side of the park... that was the first load ever in the back of that truck.
