It really depends about nozzle size more than anything else. A 190/75 is more driveable than a 155/100, all things the same. Like matt said with correct tuning the 175/75 would be the better choice, plus you can have more power on tap when youre not towing.
In a towing or cruising situation, i highly doubt youre running 2.5 ms of pw, so at that point the 155 or the 175 woudl make no difference.
The reason a 155 may run cooler towing is it MOST LIKELY doesnt have a 100 percent nozzle. Where as a lot of 175s might. This would be a VERY good reason for the 155 to run cooler.
Another thing to consider is turbo choice. What are you power goals? Honestly, if youre not going over 500, i say stick w/ a stock turbo. The powermax imo is really not that much greater than s tock turbo. It does have its place, but it doesnt belong on a truck that tows a LOT and wont be going over 500 hp anyways.
