cutthroatxxx
- Joined
- Aug 1, 2014
- Messages
- 143
- Reaction score
- 0
Ok so I had started a thread about my icp It was bad info& with it being labled as an icp thread noone would see the real problem more thsn likely so I decided to start this thread.So heres the deal 99.5 7.3 cc lb 4x4 dually bought in aug & its been a headache.Fp went out replaced &did tank mods kept blowing maxi fuse for fuel pump.Found a shorted wire.Now it has no power &@idle if you hit the fuel it will sound as it should then makes a weak sound bogs down&blows white smoke.
I flipped oil cap upside down dosnt blow it off.A little white.smoke comes out of it but not much.Idk read it.could be mat sensor,injector.o.rings,cup,or injectors or poor compression.I hope to hell its not a compression issue.But Ive dealt with poor comp before & this.feels diffrent to me.But noway to tell till I run a comp test.So what do you fellas think?We ran a buzz test on injectors&all went well.How else do I check the injectors?I was told where to hook up a gauge to check fuel pressure in my fuse post but Im not sure exactly what to buy gauge wise or where seeings it seem I have to piece together everything to check fuel pressure & compression.Also I noticed no strong smell of fuel in exhaust.I tryd to check hpop but allen head was strpped out.So troublshooting tips&Ideas would be appreciated.Sure Im getting annoying sorry
