Who's ran what with 250/100s
isootmypants
North Jersey
I ran a s300 based 72/74/1.15 with those size injectors. Loose exhaust housing so I didn't have to gate it, less back pressure etc. didn't lite like a 38 but did hit hard and made great power. I towed with it, dd, raced.
thuglike
Linden, NJ
Looking at a turbonetics super 72... That in getting a screaming deal on. Question is is 250/1s enough. Driving at 5k-7k ft elevation
Smoked a bit
Turbo lit
That was it
Gonna be a problem. I think you'll need the tightest housings you can get or a bit smaller lung all together.
There are some tuning tweeks that can be done to help light the chargers but at that elevation it may not be enought to satisfy you.
thuglike
Linden, NJ
Jacob from htt and Luke (short bus) are good resources as well..they have plenty of expeience with the mid sized lungs and elevation. They have both tried a variety of turbo's and injector sizes
97stoker350
south central pa
I don't think its gonna be CLEAN with a single in a 7.3 at that elevation but u might be able to get her close with a LOT of tuning and geting the turbo where u want it
thuglike
Linden, NJ
Would going with a 200% nozzle be beneficial or would I need more cc as well?
I want a clean 575-600
Smoked a bit
Turbo lit
That was it
I love that nozzle!!! You'll burn cooler for sure. Egt's are very manageable!!
It is alot of fuel. You'll have a slight haze but nothing stupid.
Playing with timing delay, icp, dc, fuel tables and shift points any combo can be tuned to be real clean and powerful. I would rather you went with a 200% nozzle and the larger lung than go a little smaller in both regards.
isootmypants
North Jersey
When you mean laggy. What are we talking bout like 3-4 seconds ?
Smoked a bit
Turbo lit
That was it
Yikes. Maybe an s475 at that altitude but I don't think a 66 with a .91 or something should be that bad. I'm not to familiar with different sea levels and how turbos would react but I'd amagine something the line like this..... Floor it from a dead stop *one two lite* burn tires
littleredstroker
where the antelope play
I'm talkin like cruising 65 mph 2-3 psi. Mash the skinny pedal, and how long till it blows rubber all over the fender
Smoked a bit
Turbo lit
That was it
97f350stroker
Burgettstown pa
I ran an s465 with 83 exhaust and a .9 housing. I thought the 65 was gonna be too small but with 5 speed and losing boost every shift it was nice to have a turbo that lit quick. Turbo came on around 1800-2000 rpms and pulled like a mofo. I wish I had some drive pressure numbers for you but I never got them before I wrecked it last winter. Had some smoke down low but cleared up pretty quick and it was virtually smoke free if cruising along and mashing it.
