My 6.7 venture
Athens, IL
Well its been a while since I have updated this. The trucks been a large mockup piece for turbo stuff the last 10 months. Finally got it back together.
For now it has our prototype stroker single pump, Barder 68mm 2015 charger, ported heads, ARP head studs, our hd springs and retainers, r&r rods, 2015 crank, machined and coated pistons, tig welded crank and cam gear, 2015 front cover, coated bearings, ported intake manifolds, 100% injectors, wastegate system, prototype 6r, high stall converter. I am probably forgetting a lot.
have been driving it the last couple days and everything seems to be working very well. Traction is non existent in 2wd blow 60 (even broke them loose close to 80). It runs extremely clean for 100% over injectors, unless you just mash on it. Trans is shifting crisp and quick. It sounds awesome with the new 7" stack (for pulling and racing purposes). Went to the body shop to get an estimate to get it all painted, roll pan installed and looking nice. Going to get it to the dyno next week to see what this "stock appearing" setup will do.
https://www.youtube.com/watch?v=426eggdwYAY
Athens, IL
You need more white smoke:)
Yeah I was a little disappointed with the smoke quantity. It was in 5th gear by the time it passed the camera. 420's just didnt do it.
Awesome Morgan! Can I ask the reason behind the other parts from the '15? Crank/front cover ect...
Last engine had crank-bearing failure. Using the newest available options when going back together with updated parts.
ChattyCathy
Well I have watched the lightning do a burnout like that and run a 9.20 lol. You gonna do some drag racing this year?
Why not wrap that thing?
Athens, IL
Haha, yeah I'm planning on taking it to Rudy's, TS and some other places.
It may get wrapped but I want to get everything white and use it as a background for wrap. Cutout style wrap. Was planning on doing a possible matching wrap with the pull truck. Someday.
