Better get it fixed in time for the 4x4 Jambo! I'm anxious to see it
I got the trans out last night. It may not be as bad as i thought. No metal in the fluid. Normal schmeg on the magnet/drain plug. Input shaft is in tact. It looks like i tore the splines out of the convertor. I'm hoping i can just change the fluid and filter, Flush the cooler, and install a magnafine inline filter along with a new convertor and input shaft for preventive measures.
Gordon did the same thing on his BTS with his cummins powered Ford. I also just had the same thing happen to my new BTS torque converter. Only made it 40 miles before I took the splines out.
What kind of power are you guys making to break the splines?
First time no. Gordon didn't have to either. I did the second time since I let the truck idle for 20 min with my two year old in it with the AC on. So I think that took it out. Yours is probably just a stock shaft. I think you have to be special to have a billet one lol
You don't make any power anyway!!!Yeah I hardly got on it and took out the splines. Wasn't even in a hot tune. LOL
I know i am not special enough to need one.![]()
