Aftermarket Intakes, worth the money?
Mwilbur516
I'm still using my stock intake and filter and was wondering what everyone around here thinks of the after market intakes. I've heard the K&N let dust and crap thru and aren't good at all on these engines. What about other companies? I see a lot of AFE and Air Raid in sigs.
I know the Donaldson filters great (if not the best), but what about flow? If the stock unit will flow as good or nearly as good as an aftermarket setup, then I don't see wasting the money. I'm not looking for bling, but for performance. Tell me honestly what your intakes have done for you and any problems you might have had.
BlueWaffle
Grapevine, TX
your stock one moves plenty of air for up to about 500 hp. i didn't get an aftermarket one until turbo and injectors went in...
SIX_OHH
In the Brig (Banned)
I put a afe filter in my stock box. With a zoodad. I dont think it gets any better than that.
Mwilbur516
I'm planning on some 155's and a Powermax in the future
Did the AFE make any noticeable difference? Do you think it filters as well as the stock unit?
yeehaw
Dodge County,Wisconsin
i have the S&B in mine, it sounds way better than stock. But for performance i really havn't seen much more. At first it seemed to spool up better but think that was all in my head.
SIX_OHH
Less smoke at wot is the only thing. I Doubt anything filters as well as a stock unit. But I Really think what i have is perfect. Its just a whole with a line of filter protected from engine heat. And it will stay this way until its twined.
6.0dirtworker
Cloud 9
:whs:
Dont think there's any difference than stock. Makes you hear the turbo more.
BlueWaffle
Grapevine, TX
I wanna know where this 500hp number comes from.....
the cfm of air required to match the fuel to make 500ish. The stock system doesn't flow enough air to support the cfm required and could become a restriction. Ex...to hit 500 hp you need x cfm...stock only flows y
