Couple questions for the track masters
Derek@Vision Diesel
Canby, OR
We are in the process of setting up our shop truck that will eventually see quite a bit of track time. Currently itll be a 600hp toy and then after about a year it is going to be competition only vehicle.
It is a 2003 single cab long bed.
Question we have currently is about leaf springs/shocks.
We are going to do brand new leafs front and rear.
1) What manufacturer can provide stock height springs and what does one look for in an aftermarket spring when setting up a leaf sprung truck for 4x4 launches
2) Planning to go F250 stock height up front and F250 stock height springs in the rear with the block removed to hopefully sit level. Any reason this is not a good idea?
3) Shocks... any and all advice is welcome. Seems like Fox is a popular builder.
We will run OUO adjustable length traction bars in the rear.
Thanks in advance!
Radioflyer
Fox, QA1, or Rancho 9000XL's would be my choice on shocks for mainly racing. max'd out is running QA1's and give you full adjustablility.
Derek@Vision Diesel
Canby, OR
good to hear! There are just so many options on Fox's site that it gets confusing in a hurry unless you hear from someone that has some experience with them already
I would weigh the rear end and have the spring built for that weight.
Personally I would run a caltrac like bar called assassin bars made for 1500 Silverado which are the same spring length.
Derek@Vision Diesel
Canby, OR
We already have the bars set up with OUO, that is all taken care of.
Got shocks ordered up...
I believe we are going to do A code Excursion leaf springs up front to bring the front down a little bit.
Rear springs are what I am questioning. I know it matters on weight of the rear, unfortunately the truck is torn down and the frame is being powder coated so its tough to weigh it before ordering.
T, U, or V for rear springs? Only difference is the weight they are built for, which in turn will change ride height a little bit. We are not going to run rear blocks in order to bring it down to the Ex height.
swinky
Eastern, Nc
Fwiw I'm running no block rear and stock height front but it still sits a little low in the front. It's pretty damn level but just a touch low in the front.
Excursion springs up front sounded like a good idea to me but I just don't like how soft they are. Dual shocks in the front will help big time. Running single 9000 ranchos has been a good setup as well. If you're going to run excursion springs up front you will want the lowest springs possible in the rear.
swinky
Eastern, Nc
Stock front no block rear.
Derek@Vision Diesel
Canby, OR
250 and 350 rear springs are the same or different?
What front springs are you running to give it its current ride height? How does it do when you launch it on 420s with the power you have currently?
swinky
Eastern, Nc
Honestly not sure on front springs, I'll go check. I was always under the impression 250 and 350 springs are the same. The difference is the block. I still have my over load leaf in. I'm going to remove it and will drop another half inch in the rear.
Derek@Vision Diesel
Canby, OR
I think we are going excursion fronts and then modifying the rears enough to sit level, using a rancho 9000xl shock and straps to firm it up at the track if need be.
Should ride great on the street though
swinky
Eastern, Nc
That should work. I have no idea what code my front springs are. Somewhere right in the middle. What are you planning on doing to the rear?
Derek@Vision Diesel
Canby, OR
And we could always remove one more leaf in the back to help... A little bit lower in the front would be fine with me, as long as it isn't low in the back.
Breaking Habits
Mapleton, Illinois
Derek,
Have you seen Daves new conversion kit for the front of his excursion w/ the 3 link? I dont wanna say too many details until we are ready to post it.. but maybe you should ask him about doing one of those for this truck.
