2015 test mule
Athens, IL
Sean@StreetDiesel has one of our 2200's and Mike@No Limit is getting a 2200 with his trans he's getting from me. both of those trucks have bigger s400 or precision chargers, dual fuelers and built engines.
uga33
Cartersville, GA
The Revmax guy on another forum was doing a comparison of the Aisin, Allison, 68 and 6r140. The OD clutches were the only complaint he had about the 6r140. I hope to be calling you in the next month or two about a 64mm. Thanks for all the info.
The-Fett
In for numbers as well.. also could you use the 68 for towing on say a tow tune, only towing 18k?
Athens, IL
I've got some write ups to do from the last dyno sessions. I'm working on the intercooler testing data logs which are stuck in the edge and I cannot extract for some reason.... We were having fueling issues with dual fueler tuning. It was only making 588 hp....
It's getting better but we still cannot get the pcm to put out enough ipw to fuel to 2300US.
The 68 is not a turbo I would recommend for a dedicated tow pig. But I have towed about 13k with it and it did well. Egt's were in the 8-900 range.
Administrator
thank god. I was about to start a gofundme in your name. looks great buddy.
Athens, IL
