Update on my rig
Erikclaw
Central CA
Sent from my SM-G920V using Tapatalk
Erikclaw
Central CA
No it is motor oil. All over my wg pipes, trans, crossmember under the motor etc. Just degreased it now gonna see if I can see where the *** this latest mess is coming from.
Erikclaw
Central CA
from what I can see it is running down the head gasket rear drivers head. It is leaking above there somewhere. I can't see it from above, thinking either the turbo oil drain o ring was pinched or the oil cooler ****** plate. Ran for a couple of min and ten min later a puddle like the pic is there.
SEABEE08FX4
Montgomery TX
Look in the valley, I had one that had a leak from the remote mount plate area that ended up being a compression fitting that needed to be snugged up some more. How is the drain on the HP turbo done ?
Strokersace
Towanda, KS
Your sense of patience is amazing
AND... The depth of his wallet! I mean heck, to pay someone else do do all this stuff on a vehicle has to cost a fortune. And to still have issue... The to pay someone to fix those!!
My hats off to you Erik. Oh, and are you looking at adopting? Because I'm looking for a new family! Lol
Erikclaw
Central CA
I've already looked there, you can't see chit
Erikclaw
Central CA
I am not paying for this. are you retarded? If it is any of the issues I think then whom ever put that part in is coughing up this bill.
pog
psa
run maple syrup instead of oil. it'll plug any leak and run better.
