Dirtclod
Pilot Mtn. NC
Changed oil and drained water/fuel separator. I didn't use synthetic just straight oil. My block heater isn't working and temp outside is 8 degrees. It didn't want to start,had to give a lil throttle and she did just fine. Is there anything I should use for an oil additive? Might put it in dealership this week and have heater installed. Hopefully stantadyne will be ok for the fuel.
turbie
West Jordan, ut
does a site sponsor offer it? or 8s it copied from one?
Its not a sponsors kit, nor is it anything that has been done yet. The only filter on the market that comes close is the fs2500, and they come up short.
I know that's hard to believe, but its a completely new product coming to the market soon. If you want to see it, pm me and i will give you the site.
bhudson
Mobile, AL
Ok. I'm gonna let you in on this so your old man won't kick your ass if this happens again. Get some old floor mats. Next time that happens, put those under your tires and drive out of it
dsberman94
Pennsylvania
Tie a 12"-16" 2x4 onto the tire. Low range and crawl out spinning the tire slow. Every time that board catches it'll grip and walk you out some more each time. As long as your spinning slow enough, if your spinning to fast it'll just chop a big chunk out and you won't move.
bhudson
Mobile, AL
Yeah, but the problem with the board is it doesn't cover enough area. The floor mat is easy and works great in sand too
dsberman94
Pennsylvania
I've seen both work. The board does work as long as you can get it to grip. Wheel spins till the board catches. Then you move a bit. Just do it enough times to get out. I've seen some crazy stuff with tie down straps and trees too.
Bair
Pinehurst Idaho
Stuck it last night. Pulled it out this afternoon
Those tires don't look like they shoulda stuck you. Also with no mud splattered on the windshield and roof I'm gonna go with, not enough wheel speed. Shoulda looked like a manure spreader walking through that mud. Partially kidding. You were in the yard after all.
