best leveling kit for 16 super duty
JRLott
TX
2.5" with a TEI would get you to 3.5 couple that with the appropriate block/springs out back, and you're where you want to be.
Black AOD
Ohio
Black AOD
Ohio
This. With a 5" or 6" block or traction block if you're into those, will give a good stance.
Sent from my VS990 using Tapatalk
Powerstroke214
Baton Rouge, LA
...eigthedededed...
The cheap kits are just that, cheap. I'll also add the PMF kit to the suggestions, it utilizes Icon coils, the shocks of your choice and PMF 3 link or 4 link, traction bars and trac bar and blocks
13farm
Might look into a pro comp nitro level. They made a 3.5. Haven't used one but that's what local dealership is putting on the trucks they are selling already lifted. Not sure if they are available fo 16s yet but I knew they were for the 15s
16s are identical to the 15s.
I personally wouldn't touch pro crap with a 10ft stick.
JRLott
TX
Why not? Are they so bad they won't hold up to rigorous mall crawling and pavement pounding?
