sunrisefordparts
Is the wiring harness for roof clearance lights available? also is the plug/pig tail that goes into the clearance light available separately ?
2012 f250 Thank you
whats the last 8 of your vin, I can use how you truck is built to get the correct harness. the pigtails would end up costing you more money for all 5 vs the actual harness from ford
sunrisefordparts
Pricing please on a tri-coat white tailgate handle for a 2014 F150 and also
tri-coat white rear driver and passenger side door handles for a 2015 F250.
I'm trying to de-Platinum my handles.
If you need VIN #'s just lemme know...I can provide pretty easily.
the handles from for will come as a paint to match.
tailgate handle list $98.02 sell $70.57
lr handle list $92.67 sell $66.72
rr handle list $92.30 sell $66.46
q#434646
sunrisefordparts
2001 F350 4x4
Need:
(2) axle seals - F81Z-3254-CB
(2) dust seals - F81Z-1S175-HCA - unless the new style dust seal would work but I believe those are only for 05+ trucks?
(2) hub yellow o-ring - F81Z-4A322-AA
Trying to decide if I am going to stick with Ford factory auto hubs or switch out over to Warn manual locks. Putting all new seals on the truck so feel like I mind as well stick with factory setup...Please quote me for:
(2) new auto hubs
New vacuum hosing from the hub to the first connector for both sides - does Ford even offer just these lower sections or is it a whole kit from the pump down?
Thanks!
f81z.3254.cb list $63.67 sell $45.84 each
f81z.1s175.hca list $28.75 sell $20.70 each
f81z.4a322.aa list $8.90 sell $6.41 each
hub 1c3z.3b396.cb list $315.25 sell $226.98 each
as for the vacuum hose at the hub that is only sold with the brake hose, as for up to the solenoid those are sold as one unit.
q#434641
baddkarmaracing
harlingen,tx
how about a leather wrapped steering wheel (black) for my 2011 f250 with out steering wheel controls? its an xlt and has the regular wheel but its bent and I want to replace it with one that is leather wrapped. only buttons on the wheel are for the cruise and the driver info center or what ever its called
sunrisefordparts
all the leather wrap wheels show that they will have full controls in the steering wheel. possibly the regular style like yours would work but Im not sure.
ncollins64
winchester springs, tn
Truck is a 2013 f350, ccsb, platinum with the black leather interior. Id like some prices on the center console lid with the leather and also all 4 door arm rests with the padding and leather. Thank you
Lugger007
Ct
Ok thanks. Here's the last 8.
Ceb41234
Also rear rotors, and front/rear pads same truck
sunrisefordparts
the center console lid list $825.00 sell $594
as for the door panels they are only a complete assembly.
sunrisefordparts
Ceb41234
harness for roof lamps list $78.93 sell $56.83
rear rotors list $121.43 each sell $87.43 each
rear pads list $83.30 sell $59.98
front pads list $83.30 sell $59.98
q#435043
shipping $20 for brake parts.
