13-16 Spartan tuning
cappa
Red Deer, ab
Finally got mine done with ndash and sotf. Wanted to give a shout out to Mike @no limit. Good guy to deal with putting my setup together and always answered my questions along the way no matter how stupid they were. Running the qr on the 500 right now, I told myself that is as high as I'll go until I can monitor egt's. Seems to shift good thou and pulls plenty hard, can't imagine how the 600 must feel. I pulled a probe out of the exhaust and put it in the blocker plate and plugged it into the egr, found the pid but the value doesn't seem accurate atm. Pretty happy with the spar setup thou
nlewman
So I'm a tad confused here, I guess. I thought the nga uage was the top of the line, not the nd ash
Sent from my SM-N910V using Tapatalk
cappa
Red Deer, ab
Pretty sure the tunes are the same for both just different style monitor. Ngauge is a round style monitor and the ndash looks like the one in my picture. I think ndash might be able to monior more pid's at once but i'm not for sure on that. Ndash just came out a couple weeks or so ago. Someone correct me if i'm wrong
Administrator
actually the Ndash is the full led montior and the ngauge is just a round gauge.
Cappa - glad you're happy brutha !!!
what do you mean that you plugged it into the egr? as in the egr conector plug or the probe wire plug from the egr?
cappa
Red Deer, ab
I used egt probe 11, which was the first one in my exhaust on the stock setup according to the monitor and plugged it into the egr connector plug that used to read egr egt. Then I found the spart@n egt using egr pid. I assume that's how your supposed to set it up but I could be wrong. Maybe that's not how is supposed to be setup at all and that's why it isn't reading accurately for me. I think ndash needs an update before it can monitor the egt's thou last I heard. Boost doesn't read at the moment either.
if there is a egt probe already in the egr track, why cant that still be used? is it because the egr is shut off or gone?
cappa
Red Deer, ab
Yeah I removed that whole pipe and blocked it off. Only reason I set it up that way was I thought on the mini max that was how guys were setting it up. I just wanted it all ready so when the update is out I would be good to go.
TexAg56
Corpus Christi, Texas
Cappa, I have the exact same thing done, as this is how people were doing it with other tuners. From what I understand is for Ndash or Ngauge we will need to buy an adapter before it will work and also it wont work until the update. I just dont understand where the adapter will go.
15Platinum67
I haven't been able to get ahold of them either been waiting on custom tunes for two weeks now sent multiple emails with no response!
