sunrisefordparts
Can I get a price on an oil pan for a 2000 f350 4wd with a 7.3 and also a set of U and V code front springs.
Also a bottom transmission mount for a 97 f350 4wd with a zf5 trans. Thanks
oil pan list $300.82 sell $216.59
u code springs list $251.33 each sell $180.96 each
v code springs list $251.33 each sell $180.96 each
as for the mount that is obsolete from ford
shipping $50
sunrisefordparts
I need the pulley that goes in place of the a/c compressor, on a truck without a/c.
fender list $244.30 sell $175.90
****** pulley list $107.65 sell $71.05
filter cap list $27.44 sell $23.05
we try to stay away from shipping any sheet metal due to the rick of damage and cost to ship. the other part would be free shipping.
q#472225
Could i get part number and price for torque converter, valve body/solenoid pack and trans pump for 2014 F450?
do the solenoids come separately or are they a kit? does the kit include valve body?
sunrisefordparts
does this truck have pto provisions or non pto? also the solenoids can be separate or as a whole with the valve body.
non pto. quote solenoids with valve body.
Can you also provide part numbers and pricing for exact same parts on 2011 f250?
sunrisefordparts
both trucks use the same parts
converter cc3z-7902-d list $815.22 sell $586.96 w/exchange (core $70)
valve body bc3z-7a100-b list $667.27 sell $480.43 w/exchange (core $275)
pump hc3z-7a103-a list $416.12 sell $299.60
q#472993
ford_trck
Vail, AZ
Early 99 F-350 single Rear wheel CCLB
Rear Brake hoses. All three of them, Frame to axle and the axle to the calipers.
Exhaust hanger, the one that is next to the fuel tank and is the double mount, I believe it is the second to last hanger.
Thermostat housing
Hose that goes to the drivers side of the shunt tank.
sunrisefordparts
Thermostat housing
heres the quote
  • Q473855.pdf
