how do you tell what one you need or can try in order to rule out if it went to hell or not?
my dually, as some of you know, has been on a 2yr menstrual cycle and im running out of ideas to try and fix her..
voltage drops below 14v and as low as 12.1 while driving after 45 min to an hr so there is a severe draw somewhere... jimdawg185 has been messing with her. he even put a custom alternator on her and it still draws the hell out of it..
here are the specs on the alternator.. it should burn her to the ground if the draw doesn't get found..
