thuglike
Linden, NJ
Is that the price for these item numbers?
Maybe I asked for the wrong items.
sunrisefordparts
I couldn't make out the part numbers on the thumbnail. From what I can make out, it looks like it didn't have all the hardware. I attached the quote so you can compare.
thanks,
Sean
  • Q533041 body mounts.pdf
Jarrod B
Corpus Christi Texas
idk the name of it but its the vac line that comes down the passenger body side to connect the locking hubs above the front axle. idk if that's a entire vac line or in pieces due to the elbows.
2006 f250 fx4
the driver lower tow mirror glass, heated
2013 f250 ish
thanks
sunrisefordparts
It look like it is the entire vacuum line assembly. This part runs $52.50 plus shipping. The price on the mirror is $65.30 plus shipping. I just need to know the VIN to send you the correct one, there two different one.
Ref# Q534290
unsung
Is the discount applied with a code at checkout? I just joined because I received a 6.0 two days ago. Thanks.
unsung
4c3z-17526-aa
4c3z-17527-aa
f81z-2521452-aa
f81z-2521453-aa
(2) 5c3z-16720-na
5c3z-8213-ab
4c3z-26060-24aaa (gray)
