25% discount on ford parts to members
WhiteMamba_Scorpion
2017 F150 Access Cover Screws for Tailgate (short ones). Ditching the plastic liner and getting a spray in and the current screws are too long and have a black washer on them. I need 8 of the shorter screws that come with the trucks without the plastic liner. Also 1 of the snap anchors in the tailgate had a screw snapped off in it so I will need 1 of the anchors to replace it as well.
Sent from my Galaxy S7
sunrisefordparts
screws: List $1.06 Sell .64ea
anchor: List $1.34 Sell .80
shipping $3 (total $8.92)
Quote 528949
Jarrod B
Corpus Christi Texas
2006 f250 6.0
blue spring
hpop
head gasket left and right
rocker cradle gaskets?
water pump
stand pipes left and right and if it is in a kit with dummies, then that as well.
injector oring kit x8
intake manifold gasket x2
up pipe that flexes on the back of the turbo that connects the left and right up pipe from the manifold
ipr solenoid
long list
thanks,
jarrod
sunrisefordparts
2006 f250 6.0
blue spring
hpop
water pump
ipr solenoid
long list
thanks,
jarrod
blue spring- List $84.93 Sell $61.15
hpop- List $804.50 Sell $675.78 +$50 core
head gasket- List $201.89 Sell $157.48ea (will need dowel size 18 or 20mm?)
rocker cradle gaskets- List $35.60 Sell $27.77 each
valve cover gaskets?- List $47.60 Sell $37.13 each
water pump- List $281.84 Sell $186.01
stand pipe kit with dummies- List $165.38 Sell $119.08
injector oring kit x8- List $6.89 Sell $4.55 each
intake manifold gasket x2- List $15.39 Sell $12.01 each
up pipe that flexes - List $352.60 Sell $253.87
up pipe from the manifold- List $212.22 Sell $152.80
ipr solenoid - List $303.62 Sell $200.39
+ shipping
thanks,
Sean
quote# 530416
Lugger007
Ct
2012 f250 6.7 4wd
looking to replace on front axle both sides; u-joints, upper and lower ball joints and 4wd locking hubs and any associated parts to do such.
also the u-joints from both drive shafts
and tail gate plastic top edge piece, non step tail gate.
thank you
brian
sunrisefordparts
2012 f250 6.7 4wd
thank you
brian
can I get the last 8 digits of your vin
thanks,
Sean
sunrisefordparts
2012 f250 6.7 4wd
thank you
brian
axle u-joints- List $101.18 Sell $72.85 each
upper ball joints- List $88.22 Sell $58.22 each
lower ball joints- List $106.44 Sell $70.25 each
4wd locking hubs- List $583.80 Sell $385.31 each
4wd hub locks- List $190.05 Sell $136.84 each
u-joints front drive shaft- List $44.30 Sell $31.90 each
u-joints rear drive shaft- List $60.12 Sell $43.28 each
tailgate molding- List $78.80 Sell $56.74
thanks,
Sean
Q530757
Jarrod B
engine heads. idk if they are the same or a left and right.
18mm
2006 6.0
thanks
also what do yall do about the cores or how do you process them?
sunrisefordparts
18mm
2006 6.0
thanks
List $1567.31 Sell $1128.47 each +$250.00 core + shipping
you would have to pay the core charge, and then we would refund it to you as soon as you return it
thanks,
Sean
Q531360
Jarrod B
hpop
icp sensor on pass valve cover
degas bottle
degas bottle cap
the y hose under the degas bottle
upper radiator hose
upper and lower cab bushing with bolts under the radiator
oil cooler
front and rear axle bumper stops
radiator
driver door window switch
blue spring kit for fuel
2006 f250 6.0L Crew Cab fx4
thanks
sunrisefordparts
hpop
degas bottle
degas bottle cap
upper radiator hose
oil cooler
radiator
thanks
hpop- List $804.50 Sell $675.78 + $150 core
icp sensor on pass valve cover- List $167.15 Sell $120.35
degas bottle- List $132.23 Sell $95.21
degas bottle cap- List $11.11 Sell $7.33
the y hose under the degas bottle- List $78.80 Sell $52.01
upper radiator hose- List $36.95 Sell $24.38
upper cab bushing- List $31.92 Sell $22.98 each
lower cab bushing- List $24.25 Sell $17.46 each
bolts- List $15.54 Sell $9.32 each
oil cooler- List $ 439.833 Sell $316.68
front bumper stops- List $8.68 Sell $6.25 each
**may require updated bracket (need VIN) - List $11.17 Sell $8.04 each
rear axle bumper stops List $11.13 Sell $8.02 each
radiator- List $403.75 Sell $290.70
driver door window switch- List $120.07 Sell $79.25
blue spring kit for fuel- List $84.93 Sell $61.15
+ shipping
thanks,
Sean
Q532897
