Cazador
the main vacuum harness has a list price $41.48, your cost $28.62
there are also 2 jumper hoses that go to each hub List $6.33 your cost $4.56 each
thanks,
Sean
Q591389
Thanks Sean got them fast and I’ll be ready for this wknd
Denver
America
Water pump for a 2002 F250 7.3 diesel. Also need a thermostat, thermostat housing, and lower outlet that connects to lower radiator hose. If a Ford sealant is needed, include that. Shipped to 85374.
Denver
America
Does the pump come with all the gaskets and seals?
sunrisefordparts
Water pump: List $399.60 -- your cost $241.76
thermostat: list $48.02 -- your cost $30.37
thermostat housing: list $39.69 -- your cost $25.10
lower outlet: list $77.44 -- your cost $48.98
lower outlet gasket: list $6.27 -- your cost $4.14
shipping: $16
thanks,
Sean
q591898
can you guys look up parts for 2020 superduties yet?
Im trying to get a set of black tremor headlights ordered
Here is a vin from a platinum tremor 1FT8W3BT1LEC29093
ncollins64
winchester springs, tn
2015 F-350 dually, 6.7, crew cab longbed,4wd, not a cab and chassis. Pair of rear spring packs including the small spacer between the pack and top overload, with the top overload. Need a vin?
sunrisefordparts
Yes, can I get the last 8 digits of the vin
thanks!
ncollins64
Hi,
List price $84.93 -- your cost $57.08 + shipping
the kit includes all the seals needed for the fuel pressure regulator on the side of the filter housing.
If you need the seals for the other fittings, they are sold in a separate kit... List $51.17 -- your cost $34.38
thanks,
Sean
Q590853
Can you send me a PayPal request for both kits, blue spring kit and the other o ring and seal kit shipped to 37330. N_collins73@yahoo.com. Underscore between the n and Collins. Thanks
kleake
Sapulpa, OK
Cost for wheel bearing/hub on a 2011 Explorer Limited 4x4. I believe the bearing is the same for all locations, but I suspect a front one is making the noise.
