25% discount on ford parts to members
Leftthenleft
Nc
mirror caps: RH- List $103.41 -- your cost $68.33
LH- List $107.63 -- your cost $71.12
outer grill surround: List $215.38 -- your cost $189.53
the inner bars are only showing to be available in chrome, satin brush aluminum or black, catalog doesn't show a paint to match option....
if you want to go with the black ones- List $77.27 -- your cost $48.31 each
shipping is coming up at $84.58
Thanks,
Sean
Q590000
Would like to do black in that case. There are 2 bars in the center and then the 2 “[“ shaped pieces on the ends. $48 per piece times 4 pieces?
I’m going to get the mirror caps and surround for sure, just trying to understand the center portion. Thank you
kleake
Sapulpa, OK
price for upper radiator hose o-rings. It was a new hose a year or two back, but the engine side is now seeping. Might as well replace both ends.
sunrisefordparts
sorry, I missed the two [ shaped pieces...
they are List $36.99 -- your cost $27.68 each (also in black)
I added them to the quote
thanks,
Sean
Looking for part number and pricing on adding OEM remote start to a 2019 F150.
Do i have to add an extra fob? or do they offer a kit with keys that have the additional button.
sunrisefordparts
The module kit KN1Z-19A361-A comes with the module and harness: It will require programming by a dealership. List $207.61 your cost $159.86 There is a way that it can be configured to use your existing fob to operate the remote start.
Alternately there are addition remote fobs you can purchase JS7Z-15K601-B they list for $95.00 your cost $73.15 each.... These fobs have a little led light in them that will let you know if the remote start was successful...
thanks,
Sean
Q590164
Lugger007
Ct
looking for pricing for 2012 f250 diesel srw 4wd shipped to 06484. thank you
front rotor (5C3Z-1125-AB) & pads
rear rotor (5U2Z-1V125-ME) & pads
front driver side wheel hub assembly DC3Z-1104-C
transfer case fluid
rear passenger side brake assembly BC3Z-2209-A
rear axle seals for when pulling the axle
sunrisefordparts
transfer case fluid
front rotors: List $167.22 -- your cost $103.01 each
front pads: List $66.84 -- your cost $42.27
rear rotors: List $161.29 -- your cost $99.36 each
rear pads: List $60.93 -- your cost $38.54
front driver side wheel hub assembly: List $687.25 -- your cost $415.79
transfer case fluid: list $6.43 -- your cost $5.78 each
rear passenger side brake assembly: List $341.23 -- your cost $243.98
rear axle seals: List $26.33 -- your cost $33.30 each
axle orings: List $2.13 -- your cost $1.54 each
shipping is coming out to $168.26
thanks,
Sean
q590812
sunrisefordparts
2006 Ford 6.0 powerstroke
Blue spring upgrade kit. Does this include the seals and o rings too reseal the housing that’s prone to leaking?
Hi,
List price $84.93 -- your cost $57.08 + shipping
the kit includes all the seals needed for the fuel pressure regulator on the side of the filter housing.
If you need the seals for the other fittings, they are sold in a separate kit... List $51.17 -- your cost $34.38
thanks,
Sean
Q590853
Cazador
Looking for hub vacuum lines for 2011 f350 lariat 6.7 and the availability thanks
sunrisefordparts
the main vacuum harness has a list price $41.48, your cost $28.62
there are also 2 jumper hoses that go to each hub List $6.33 your cost $4.56 each
thanks,
Sean
Q591389
