What is this plug?
JohnT24
OXFORD CT.
Actually 2 questions:
What is this plug for?
(1995) F350 / behind front grill
How do you remove the cable from the hood latch?
Strokersace
Towanda, KS
Plug is for the daytime running light module, if the truck was equipped with it.
What I’ve done to remove the cable is take some needle noses or other pliers and pop the end of the shielded part out (circle where actual cable comes out) of the metal retainer. It’s pressed in. The end of the cable is a hoop that is behind a plastic cover. Pop that cover off and you can take the cable hoop off the latch completely. Hope that makes sense.
Parker, TX
As mentioned, the plug is for the DRLs. It either gets a DRL module plugged in (for DRLs) or it has a "shorting plug" inserted (for trucks without DRLs). That one looks like the plug is installed. Cheers!
DEEZUZ
NO PUKESTERS
NWI
Jesus that thing Krusty..are we sure it's worth the work?
JohnT24
OXFORD CT.
Thanks stroker ace
Yep
That made sense.
I’m going to clean it up and take a closer look today.
JohnT24
OXFORD CT.
That’s living in New England for you.
Yeah the bones are good.
There’s just a few pieces I need to fix up.
It should last me another 26 years
[emoji12]
Sure beats $70k for a new one.
DEEZUZ
NO PUKESTERS
NWI
Jesus. I didn't even know that piece came off. Lmao. I've always lifted 7.3s straight up on OBS
