Rear a/c line
Diesel X
Rear a/c line was hit with a piece of road debris and cracked it. Is the front and rear a/c system independent of each other? Does the body need to be rised off the frame to put new lines on? Looks like a pian to do either way.
psduser1
on the road
One system, front and back share common refrigerant.
No, you don't have to pull the body to change a line, however you'll need to evacuate the system before replacing the lines.
Powerstroke Cowboy
Montana
Just a slight crack . What would you splice it with
An AC splice kit. I will PM a link to a thread on how to do it. Either than explaining.
You could also braze it.
To hose wondering, I do not want to get in trouble by posting a link to another forum.
Gnathv
These work surprisingly well.
Diesel X
Got the ac splice kit. Didn't need it. Turns out it was the rear heating line. It was the 2nd from the bottom line. Figured it out when I cut the line and antifreeze came out. Used some 5/8 inch heater hose and some new clamps. Topped off the antifreeze and no leaks
