E4od occasional slipping
psduser1
on the road
Looking for a bit of info on this transmission. My boys 95 is having shifting issues, occasionally. No forward or reverse at times, and it seems to be when the Trans is cold.
Not all the time, and not consistent with the weather, but worse the colder it gets.
I haven't pulled any codes yet.
I'm thinking it's a valve issue, but not sure. It seems to shift normally when everything is warm.
Tiha
Super Moderator
Super Mod
My understanding is that an E4OD should move forward or backward without electronics.
So that means you would have a loss of fluid pressure.
Probably pull the pan and inspect. Maybe the filter is loose and it is sucking air? Or fluid is low?
psduser1
on the road
I'll have him check those things again, but the fluid has been full, and bright. No signs of overheating.
psduser1
on the road
Couple more details.
Trans was rebuilt approx 25k miles ago, no problems except the po didn't like the converter lockup points when driven unloaded, i.e. no trailer. With a load, no problem.
Tiha
Super Moderator
Super Mod
Certainly get the pan pulled and see what you can.
I have heard of filters falling off. Also valve bodies coming loose.
Tiha
Super Moderator
Super Mod
Take a picture of what is in the pan. It can tell us a lot.
psduser1
on the road
Dropped the pan, nothing unusual.
Filter was tight, normal friction material. I don't think it is a fluid problem. I still haven't pulled any codes, so that's on the to do list.
I'm pretty sure it's a valve issue, or converter issue, but, only when cold.
Tiha
Super Moderator
Super Mod
Pan looks great. Also put a wrench on the valve body bolts make sure they are not loose.
If the convertor drains back to the pan, it will usually still eventually pick up fluid and move.
Does the problem only occur on cold start up?
Or will it act up while driving?
Parker, TX
Probably not your issue, but the winter months I found that the rear brake shoes would freeze themselves to the drums overnight when the parking brake was set, especially if I had been out in wet weather. It seemed like transmission issues when it happened (no forward or reverse, just bogging), but it was the brakes the whole time! Since my driveway was flat, I had to remember to not set the parking brake. Cheers!
psduser1
on the road
It's not the brakes, sometimes it occurs after the truck is moving. Acts like the torque convertor just failed. Few seconds later, everything moves perfectly.
psduser1
on the road
Little update..
Boy says the transmission is doing better, doesn't seem to be slipping. He's driving it everyday, enough to get it thoroughly warmed up. Apparently, a new filter made it happy....
Still going to swap to a sd harness and 4r100, as time permits. He wants the 4x4, and, I'm sure, a bit of a lift.🙄😅
Tiha
Super Moderator
Super Mod
That is great news. Usually not an easy fix like that. I hope it is taken care of.
