Sterling6.7
- Joined
- Oct 9, 2014
- Messages
- 1,532
- Reaction score
- 102
Hi guys. I’ve been struggling with this for a couple of days now, but my new to us 7.3 was started up the other day and the WTS light stayed on for the 15 mile trip home. I was told about it afterwards so I went and checked on it and it won’t start. So after a couple of days, here is where I am at with it -
- 02 F250 4x4 7.3 with 115K miles on it
- Crank only, no start
- WTS light stays on
- Multiple scanners will not recognize the vehicle when connected, including one with Forscan, unable to read codes as a result
- Replaced the CPS with NAPA model because the local Ford dealer didn’t have one on the shelf and it’s Memorial Day weekend
- Removed PCM to check the pins, no damage or corrosion, grounding clip in place
- Checked all relays and fuses, all fuses good and all relays appear to function when swapped with blower location
- Unplugged IPC, no change
- IPR looks to be intact, including wiring at the plug
- Fully charged batteries with external charger
- Full of oil
- Fuel pump sounds like it is running when key is turned on
Can anyone help me figure out what I am missing? Thank you in advance.
- Full of oil
