38r BatMoWheel Update
Worstenemy453
Fredericksburg, Va
Yes, the 38r batmowheel will be available in about 3 weeks, i took care of this and Full Force Diesel will be buying the complete first run, then the wheels will be available through any bullseye dealer afterwards.
Full Force will be doing dyno tests showing this wheel's improvement over a standard 38r, and we are hoping to have this all done before rudy's so they can show them off there as well.
Wicked
Fairhope, AL
Well I will be calling him bright and early tomorrow. I need to get one of these. Any news if its the double or single batmowheel?
Worstenemy453
Fredericksburg, Va
I am not sure, but i believe it will just be the single. I might be mistaken but i think the DBMW only come in bullseye turbos. Ill check with Bill tomorrow.
They will have 20 of them.
Wicked
Fairhope, AL
Honestly I am hoping for allot. With the 250/100 injectors in my hottest tune it is pretty hot and puts out a good amount of smoke... I also imagine my backpressure is pretty freaking high as well (even with the 1.15 housing). I am hoping that I get some more CFM in airflow to clear up some smoke, some drop in my egt's (in my hot tune), and reducing the backpressure a little. I would venture to say the people with 200+cc injectors will get the greatest benefit... might extend longevity as well for those with bigger injectors pushing all that air threw that turbo.
Bigsexy
Lochbuie, co
I'm hoping you all can get this to help with bringing my egt temps down, as I like the 38r an would like to keep it. My goal is 250/200 injectors after I have all the supporting mods for them.
Worstenemy453
Fredericksburg, Va
Just looking at the benefits that are true of the 6.0, powermax, 6.4 and the like I would be willing to bet it would make a noticeable improvement.
Full force has arranged and reserved the first 20 which is what I have been told by bullseye will be produced in the first run. I have no reason to doubt that full force will sell them at the current MAP price of 399 just like every other batmowheel. The cost is the same acres the board.
Bigsexy
Lochbuie, co
I've never really looked into what it does for the 6.0s. Will you guys post the results of the dyno? Als will this install similar to the same way you install a wicked wheel on a stoc turbo?
Worstenemy453
Fredericksburg, Va
You just pull your stock wheel and install it, its just like doing the wicked wheels. I believe dyno results are in the 6.0 aftermarket section.
Tom S
I would. Local shop here will balance a batmo on a Pmax for $40. Cheap insurance
My thoughts as well. On a rebuildible charger I woud be more willing to take the chance then on one that is not so rebuildible.
