2.6 6.0 build time!
sonic_superduty
waynesfield,Ohio
pics
sorry been really busy on this and work, getting harnesses swapped,bodys swapped, so on but here are a few pics of the progress! smith bros. push rods, 5 gallon cell, fuel system is not complete as of yet but you can see I have a start, 4200 Iron giant and a set of Liberator solid up-pipes..more to come!
kyle43335
In the Brig (Banned)
looks good except those pos upipes.
kyle43335
Well Kyle inform me on em ? Why POS
Its a modified stock piece. The collector flow is horrible.
The bellow on the drivers side necks down to 1.75 inches.
That y pipe is a turbulance nightmare.
Build something that will actually flow.
If you need ideas pm me and ill send you some pics
strokin6L
Springville NY
off topic, but i knew i saw a pulling tractor in the last pic of the 5 that you posted....super, super farm or pro stock?
kyle43335
this^
strokin6L
Springville NY
that's really nice Kyle! But why not use HD bellows...they look stock. Where did you get the Y collector with flange that clamps to the turbine side? Or did you make/fab that up? Also where did you get the flared ends that clamp to the manifolds?
kyle43335
those are hd bellows,made from t 304. the actual bellow is inconel.
they look similar to the stock bellow,but arent the same.
the collector is a bent merge collector from spd,its also made from t304.
the flared ends are/were 2" t304 straight pieces flared to roughly 45*.
everything was bought in raw form to make that.
the flange for the turbine was cut from a stock unit,cleaned and welded to the bmc.
sonic_superduty
waynesfield,Ohio
Well i found the right thread this time.. cab is on and should be firing it up tonite, I also had to mod the up pipes cause they wouldn't fit!, as it sits now it has a 4200 iron giant, billet HO hpop, 275/150s,ported heads, s366 batmo with a .91 devided housing, full fuel system, and so on, shouldn't be to bad to start with, but its gonna need a s4 or somthing of similar size..more to come!
sonic_superduty
waynesfield,Ohio
Had some wiring issues, but we got it all figured out, built the Hoodstack last night, and im planning on having it at the Warsaw,in test n tune this sat.
