is there any reason i cant take off the fuel tank skid plates?
Pstroke96
Connecticut
the skid plates on my truck are fairly rusty and look pretty crappy. since the truck never goes off road i was figuring that i would just take them off and toss them, but i wanted to make sure there wasnt any reason i couldnt take them off, like them holding the fuel tanks up or anything. thanks guys
Zmann
to get this bumped
on My 06 it was an option with the FX4 so not all trucks have it
I replaced mine with a Titan so it doesn't retain the steel plate anyway ,, plus with a lift your less prone to damage
mjonesjr
Salem, IN
The rear skid plates hold the tank in. If you remove it, you will have to fab something to hold the tank up.
Pstroke96
Connecticut
okay so that ones out, i was mainly conserned with the mid ship tank. since the spare tire is up there as well. the front tank has its own straps then the skid plate is under it correct?
Zmann
yup on mine the skid plate was a separate unit with it's own straps and bolts
Pstroke96
Connecticut
i might, but it will take quite alot of wire wheeling to get it all shined up to paint, it is a good idea, maybe then i will be enspired to do the rest of the frame
Pstroke96
Connecticut
i had already done the frame but i cheaped out on the paint when i did it so its all flaking off now and looks like crap
Racer X
We have several used 38 gallon rear tanks. If anyone is interested in them contact us directly or pm 4 Wings.
Thanks,
Racer
old man dave
Petaluma, CA
You can just use the 2wd tank straps. Its the 4wd that have the skid plates. RockAuto.com sells them for $15 and $20 for the side and rear tank strap pairs.
