99-04 4" and 6" lift
steele86
brush prairie wa
i looking to lift my truck but still suck on whitch one to go with i all ready ordered my tires they 37" hummer tires i just need to see some pics of trucks with 4" and 6" side by side to compair, my buddy says 6" make the truck to tall to use but i dont think so but thats why i'm asking you guys and yes i do go off time to time but 80% of the time its on the hwy. thanks guys
CSIPSD
Bend, OR
You will want a min of 6" unless your runing skinny rims...even then..
Simply not correct... I have over 200k running a 4" revtek lift and 37x13.5x17... Offset is the key.
4 inch works just rubs with 16.5x12 wides
Why would anyone want to run 12" wide wheels...
None the less, the correct offset would fix that.
A little Rubbing is not a big deal but f***ing the fenders is
I have no fender damage at all. I have trimmed the bumper on the lower front, otherwise nothing else.
nasty6.6
San Angelo, TX
Yea 4 inch on 37s looks GOOOOOD shoot id run 38s if i could of found the michelin 16s!
And yea I run 12 wides I wish i could get a set of the old school 14 wides!
Who said anything about f***** up fenders? Rubbing is all and all you have to do is trim like 1/2 inch off the bumper plastic then its fixed.
steele86
brush prairie wa
It's hard to find the correct backspaceing on 16.5. But how you determine the back space on the wheels? The guy said the wheels should 4.5 back space but he couldn't Remember .
steele86
brush prairie wa
I have a coworker that has a4 inch on 35x12.5x17 and the bottom of the fenders are just f***ed but who knows if the wheels are right
CSIPSD
Bend, OR
More then likely his wheels hang out of the fender wells a ton.
The wheels I am running now have 4.5" of backspace.
Crownsville, Maryland
I have an 02 with a 4" lift 35x12.50R17 and 17x9 fuel hostages that have 4.5 bs and-12 off set and im running 2" wheel spacers. Without my oe style flares i had no rubbing of sheet metal only the corners of the lower valance of the bumper. With the flares i only rub if i hit a big enough bump at full turn
Sent from on the commode with Tapatalk 2
Homesteader
Do you have a spring or shackle lift? I've been trying to decide my self on a lift.
Juvenile9
Mt. Perry, OH
This is my 99 F-350 with 4 inch fab tech lift. Running 35's on 16x10 wheels. ImageUploadedByTapatalk1359651530.784671.jpg
Juvenile9
Mt. Perry, OH
This is my old truck running 6 inch pro comp kit with 37" pro comp x terrains on 16x10 wheels.ImageUploadedByTapatalk1359651721.411187.jpg
