- Joined
- May 22, 2011
- Messages
- 15,240
- Reaction score
- 1
heard wayne had good results from changing his intake.
No sh#t. I never would have guessed there would be that much difference.
Stupid power gain from an intake upgrade.
At 2500rpm gain was 10hp.
At 2750rpm gain was 30hp.
At 3000 rpm gain was 60hp.
At 3500 rpm gain was 106hp!!!!
No Limit intake and Elite Diesel boot FTW!
i think the uncorrected numbers are so drastic due to the efficiency of the atmo turbo once it was breathing well. i talked to my partner about it a bit and he said he has seen the same thing that wayne saw tonight. restriction keeps the turbo from pulling in the minder , unleash the restriction and it builds boost and starts pulling in the minder. crazy physics.
Makes sense, I just never expected that big of a difference. It will be a while before my truck will see those kind of power levels, but at least I know I am already ahead of the game in the CAI department. My guess is that will help keep you even busier for quite a while. :rockon:
Close, but Erik & I built the original (the one on my truck now) back when he had me install the high powers. We tried modifying his AFE, then an S&B, but came up with this as everything else pulled in the filter minder. Haller's changed to a larger filter when the injectors went up in size. This style of intake addresses the most critcal function of avoiding pulling vacuum, and causing turbo damage, but I'm looking forward to when you release a heat shield for it if you're able to make one fit.i hope so. it was born from necessity, me, erik, and settlemire were the first with high powers in street trucks.. we all learned what was necessary. haller addressed it and settlemire and i perfected it.
