Zmann
- Joined
- Aug 5, 2011
- Messages
- 4,464
- Reaction score
- 1
this is Why I wouldn't sweat a below 14 volt output
except disregard the quickly rise portion since the Glow Plugs may be on that doesn't always happen
ALTERNATOR CHARGING VOLTAGE
Most alternators that are charging properly should produce a voltage of about 13.8 to 14.2 volts at idle with the lights and accessories off. Always refer to the vehicle manufacturer's specifications. Many Asian vehicles, for example, have higher charging voltages of around 15 volts.
When the engine is first started, the charging voltage should rise quickly to about two volts above base battery voltage, then taper off, leveling out at the specified voltage.
The exact charging voltage will vary according to the battery's state of charge, the load on the vehicle's electrical system, and temperature. The lower the temperature the higher the charging voltage, and the higher the temperature the lower the charging voltage. The "normal" charging voltage on a typical application might be 13.9 to 15.1 volts at 77 degrees F. But at 20 degrees F. below zero, the charging voltage might be 14.9 to 15.8 volts. On a hot engine on a hot day, the normal charging voltage might drop to 13.5 to 14.3 volts.
