dieselsites 05+ adrenaline
JWaltz
Is anyone running the warren pump been looking at it online it looks like a pretty solid set up but im running a hoodstack not sure i have enough room to run a secondary and just wondering how well these things are running i know jesses truck is running like 300/400 pretty well just seems like running to one head seems like it would come short but my injectors are no where near that nor will they ever be
g2shuck
These pumps aren't designed to take the side load of a serpentine belt. They're designed to be direct coupled
That issue is took care of in the warren twin pump kit. I worked with jesse to resolve this.
I am running it pm me for more info. I feed mine directly into both rails. The standar kit does not feed into one head it feeds into the test port.
im not sure jesses kit can mount up to compounds thought can it? maybe he will chime in. Also been waiting for the Pump from adrenaline....
Yess it will fit I have it on my truck with my triple turbos.
MorganY
college station, tx
Wasn't sure if you did that to yours, or its across all his kits. Do you get the truck running?
g2shuck
It's standard now we pull the bearings out of the pump and pressin ball bearings made to handle side load
TooMuch03
West Bend, WI
It's standard now. he is pressing the bearings into my pump so we will see how it works. I don't see why you couldn't run it with compounds. I will be, but my setup is weird and I am only using his pulley and bracket. Fwiw, the pump he sells with his kit is smaller than what he is using on his truck and it can't drain low pressure oil because it pulls from before the oil pump. At least thatcis what he told me IIRC.
Josh@DirtyDiesels
PA
Anyone know the exact price tag of warrens dual pump setup and also any pics of it installed. Kind of wanted to stay away from dual pumps but it has sparked my interest...
MorganY
college station, tx
Pulls oil from the pan. Same location of oil where the lpop pulls from. .
g2shuck
Anybody that wants info on the kit can pm me I have it on my truck and have installed it on anther guys truck also
Redneck6.0L
Seeing how your pulling oil from the pan, is it getting filtered at all, I'm not a fan of pushing dirty oil directly in the high pressure oil system
windrunner408
I'm not a fan or robbing oil from low pressure oil supplied components. The oil does get filtered, indirectly. It's not like the oil in the pan is never filtered.
g2shuck
correct all oil in the system is filtered throught the oil flow.
Cutting-Edge Diesel
Newkirk, OK
I consider anything that is before the filter to be unfiltered oil. I would want some sort of filtration before It went into my hp oil system and threw all my injectors. Having the oil filtered before It went threw the whole motor and back into the pan is not considered filtered to me.
g2shuck
I do believe that all oil in the whole system has been filtered and is not "dirty" but for guys that want it to be per pump filtered I am working on that… not trying to start any arguments at all just trying to take the issue tht some people have with the filtration and improve upon it Shawn. If you have any other suggestions feel free to pm me about them, and no this filtration system is not something I am working on for warren diesel this is something I'm doing just to do more or less
