ZMBYKLR Issues?
imelmo
I remember seeing bad new oil coolers a few times. That would suck, I don't see what else could cause so much delta other than bad sensors. Does it read the same ECT and EOT after sitting overnight?
Yup, always within one or two degrees.
I ran the CTS again for codes and one popped up this time- P0267 (injector circuit low, cylinder 3). I'm going to clear it and see if it pops up again. It showed that one before a while back but went away after I cleared it and didn't come back. I'm wondering if I have an intermittent problem of some sort. That would account for the low power but I still need to see what's going on with my delta.
Somebody needs to open a good diesel shop around here. LOL
Powerstroked162
On Da Juice
Wa. State
You'll know if its a problem or not once we get the new reroute kit on the truck brotha. I should have everything together to ship mañana
imelmo
Cleared the code and drove around for about an hour then ran it again. The P0267 didn't come on again, but a P0341 (camshaft position sensor circuit performance, bank 1/1 sensor) popped up now.
A little bit of reading tells me it could be the sensor itself or, for '03 to '04 in particular, the harness at the sensor. :doh:
Lubbockguy1979
Lubbock tx
What about the water pump danny? Could that possibly be causing issues? Iirc they have a plastic impellar and that could be broken causing less than ideal ect which pushes up the deltas.
Fantom
Sacramento, CA
I had the same problem with my truck after doing studs and a brand new OEM oil cooler, turned out to be 2 issues, the new cooler was crap right out of the box and the radiator was plugged up, new water pump only dropped the deltas by a couple of degrees.
