Got an alignment, just finished rebuilding the whole front end. Then drove it to Phoenix to move a pool table for my grandpa, these things are heavy! Drove about 130miles today. Plan on doing a full detail soon, clay, compound,polish, sealant, then wax. Fun
Bobby@cp
Hauled a broke down cummings home, then this afternoon smacked the side of the barn and messed up my driverside fender
Bobby@cp
What did you do that for? :poke:
I blame it on the 2 hrs of sleep I got due to the cummings breaking down.....
I was backing into the narrow side door and wasnt watching, Im pissed off at my self.
jbaal
parrish,fl
Cleaned the motor up a bit (it was a little grimey). Then tried to recharge the ac, but it didnt do much.
mandkole
Northwest
new brake controller, replacement egt gauge, reinstalled the scan gauge, new harness for headunit (broken pin), small rolling burnout (got enough powah to do that now)... good day
Enslow
Baltimore County MD
Just finished putting a set of air horns on today, forgot how loud they were! Ran the air lines into the cab to a ball vlv. Gonna fab up a bracket inside for a legit air vlv when the money is available. ImageUploadedByTapatalk1367808131.978085.jpgImageUploadedByTapatalk1367808147.212207.jpg
my helper!
stroker2
Durango/Fort Collins, CO
Put dynamat sound insulation in the two fron doors. Made a he!! of a difference. Much less road noise even at 30mph. Cant wait to see how interstate speeds are quieted down. Just didnt have enough to do the suicide doors. Will have to get more to cover those
greyford1979
Copley,Ohio
Just installed a clutch in my 7.3 it sure made the zf6 shift a lot better
did that to mine the last friday and it didnt help it shift better.... dont know if the synchro's are bad or not... the old clutch was slipping like a mofo.... this one doesnt slip one bit... 3786 lbs of true pressure!!
