6" lift fabrication
20007.3L
Manchester, NH
Any fabed up a 6" hanger drop suspension lift? Post some pics, i want to get this done and just want some idea! I also dont want to spend the money on lift kit if i can do the same thing! There has got to be someone out there that has done it!
fordfreak4life
Deaver springs for all 4 corners would run you less than 1000$ and give you substantially better ride quality
Sent while spinning 18 wheels
CSIPSD
Bend, OR
You want a 6" lift home fabbed?
Can you weld better then you bondo?
kidding kind of...
20007.3L
Manchester, NH
kidding kind of...
Ouch..............BURN! I will take that! AND THE BONDO JOB WAS A QUCIK FIX till paint LOL
Yes i can weld very good! I have welded quite a few frames!
fordfreak4life
Id like to see that, just the rears are over? 1k. You can't even get icons for that cheap
got deavers for all corners of my buddies dodge for 930$ shipped, dropped spring tension 15% for rude quality and lowered ride height 2"
